05 Silverado electrical issues..?
wardy75
  • 4 years later...
Thanks Doug_Scott for the reply. The battery is new I haven't dug deep into checking all connections yet. And honestly I'm afraid of delving too far into electrical issues. Lol..I've not washed the engine compartment but suspect it came from going through several mud puddles at my hunting club. Nothing anymore than 6"-12" deep and I wasn't rooting around. But after that was when the problems started...
I'd like to think I could fix it myself but I definitely don't have all the necessary tools I'm sure...I might could get a hold of the ones I really need.
Where are the main ground straps for my truck? Anyone know or think Google will tell me?
Via Droid Maxx using Tapatalk
You need to buy a subscription to a service information site , alldata is fair enough for an owner nontech handy guy ,
You just can’t do this without information
  • 1 year later...
For anyone having similar issues clean the connector and put silicone around the connector. Once I did this and cleared to codes everything was fine. Don’t know how water was getting in but my mechanic wanted to replace the ignition, starter, battery, knock sensors, plugs, wires, wiring harness for fan and more before I found water in that connector. I check it every 6 months and re silicone it and haven’t had a problem since. Bad ground can cause similar issues
    whenindoubtuseahammer
  • Who's Online   4 Members, 0 Anonymous, 422 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
