Nav question/AC question
My nav question is can you mark the location your vehicle is sitting at and save it? I havent been able to find that.
On the A/C how do you turn sync off? I cant get mine to not sync with the passenger side the light just stays on after i have tried turning it off.
Denali is running great, scheduled to get my xpel on the front bumper already have rock chips thats crazy. Will have to fill them before the install.
Thanks for the help.
I leave mine synced all of the time unless someone in the other seat wants that side at an alternate temp.
Hey bozfour!
Looks like you got your AC question answered! In regard you your question about navigation, our Infotainment Customer Support Team would be happy to assist you. You can reach them at 855-478-7767 between the hours of 8AM - 10PM EST seven days a week.
Have a great evening!
Andraya R.
GM Customer Care
