03 GMC Sierra 4WD Transfer Case Problem
I have a 03 GMC Sierra 1500 Z71 SLT with push button 4x4. The 4x4 wont shift at all now, when I hit 4H the light just flashes, if I hit 4L, its like Im geared down, but the front driveshaft doesnt engage. The Service 4WD message is also on. Ive been reading about the encoder motor or sensor as well as the transfer case module. Any ideas?
Scan for codes, without that it's just shooting in the dark. You'll need a scanner that can pull C codes, autozone and oreilly's rent them out for free. Sounds like either the encoder is bad or there are clutch problems. These parts are expensive and are not worth guessing. Post back with results.
    • GDI Injector tips are in the combustion chamber and yes, they are subject to the same aromatic hydrocarbon based carbon build up the entire chamber is subjected to. Chevron Techron is a PEA based cleaner (polyether amine)  that is VERY effective if the dose is high enough.  Carbon the tips disrupts the spray pattern so keeping them clean is kind of a big deal. It will clean more than the injector tips. It will keep the inside of the injector tip clean as well. When they shut off they 'hot soak' building varnish internally behind the pintle. The tip, unlike most MFI systems have several orifices of very small diameter. They have to stay clean to work right. That spray pattern is supposed to spray into the cup in the piston, not all over the cylinder walls. Old guys will understand...    Top Tier Chevron has enough of the cleaner to be effective if used regularly. Other solutions could be Shell V Power Nitro + Premium and Exxon/Mobil Supreme Plus Premium ONLY use a different chemistry to the same effect with the added bonus of a friction/antiwear additive as well. Red Line SI-1 is PEA based as well with an upper cylinder lube. There's a white paper on their site for shock treatment of system left untreated for long periods. AMSOIL PI has a full system cleaner of yet another chemistry that will strip carbon out of the power cylinder pretty quick. Gumout Regane is also PEA based but at very low doses and those that are isopropanol based will not be effective. Alcohol content is way to low. Chevron Techron in any pump gas, Use by package instructions. 10 oz per 15 gallons every 3,000 miles. First use may require two treatments.    So, Techron, Red Line SI-1 and AMSOIL PI if batch treating and Shell, XOM Premium or any Chevron Fuel will not just keep it clean, but will clean it if dirty. No other fuel "I'm aware of will do that".    Flex Fuel motors. If you use at least 40% alcohol on a regular basis they won't carbon at all. PEA is not recommended for fuels over E-20     (www.carparts.com)
    • It is always a good idea to exercise it at least every few months to make sure the actuators don’t get stuck. It is also a good idea to actually drive it for at least a few hundred feet when you do that so seals experience motion and oil movement.  Off pavement or snow/ice is best for this, but driving wet pavement in a straight line for a  short distance will work if you don’t have other options. I have  forgotten and gone as long as six months between exercising it on my 2021 and it has always shifted promptly.  I usually just use my straight 300 foot gravel driveway.
    • Absolutely!  These forums are legion with posts of people complaining that their truck wouldn't go into 4WD when they needed it to.  Most of them hadn't used it ever or in years.   I try to run mine through the paces every month or so and drive it a few miles on a dirt trail near the house a couple times a year if not already off-roading.
    • The battery is  very new, The  truck is  essentially undrivable  so I have had it  towed  to the  dealer. Since  this is an E Assist  truck  the dealer  seems  the only option at this point. Scan showes multiple  codes. The  repair wll not be  cheap
    • Not a bad idea to check codes. But, if you have an old battery and/or electrical gremlins, most of those codes will be false.
