Transfer case
If it's a dial apply the parking brake put the trans in neutral and turn the dial to" n". If it's buttons you press two of them at the same time I think and they should have a line with an "n" showing which two.I think... :dunno:
It's the dial type ... It told me to put trans in nuetral set e brake and hold dial all the way to the right for 15 seconds all it did was go into 4 low it did not go into nuetral I tried it on my vortec max and on a regular 1/2 ton chevy it did not work on either
Mine works every time when done per the owner's manual. Set e-brake, turn ignition to ON position, Trans to neutral, ensure transfer case is in 2 Hi. Then turn the dial all the way over to neutral and hold for 10 seconds.
You might have more luck with truck in neutral rolling at a very slow 2-3mph. That's the best way I've found to get into 4wd low (which for me in my manual tcase truck goes right through neutral).
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 324 Guests (See full list)
