Remote wire for sub
sareljr
Would it work to put my remote wire for my sub in with the fuse that says "aux 2", it's a 25 amp fuse, 2005 2500HD btw
Im curious if enything is is even connected to it.. Take a mult meter and check it. Also in the past i wa always told to use a smaller fuse to add onto. 15 at most.
Ive had great luck using "Add-a-fuse" pigtail extenson.
My current amp i have installed was hooked up by a professional stereo shop. They tapped in under the steering column. I dont remmeber which wire they used tho.
You need to find a source that is on with key and off with key..
