CO710
casale33
I HAVE 2011 CREW CAB silverado, once and awhile the dtc trips the co710 code [ steering position signal] which usually resets at next key cycle .. is this just a bad switch or could it be something else? i appreciate any help ..
it could be 1 of say 7 things but ya have to ask yourself a question ,,,,
do ya feel lucky ?,well do ya ?(taken from a movie i hope ya know ) lol
seriously ,dont guess ,,get it scanned and post the code and we can help you right up untill ya need a scanner to do the diagnosing further ,,,
or have them do it ,,,its not worth pissin around with imho
i had it scanned and that was the code
duh me ,very sorry
i mean if ya have the code ,that means nothing ,the dtc diag chart still has to gone thru ,,,unless ya want to gamble ,,,,totally up to you ,,,,,i see here all the time people guessing ,spending tons of cash and the condition still remains ,then they come here looking for an internet fix with no money left ,,,,
do ya feel lucky ?
yes ,, had the scanner diagram show accurate angle readings with wheel..mil can go weeks without setting ,, any ideas ,,,,bad angle sensor ?
Is your steering wheel level when driving in a straight line?
There is a tsb for this concern. They want you to add dielectric grease to the steering wheel position sensor. This may or may not fix it but its cheap and worth a try.
No I don't but basically it says put dielectric grease on the connector for the SWP sensor.
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
