Tow mirrors on 2014 3/4 ton. What yrs work?
Question about the towing mirrors '14+ trucks. I read on one forum that they were same as the ones on the '06+ trucks. I want to get a set. Dealer sells them for my truck for $320 a mirror! Anyone have any idea on what year mirrors work or good brand that doesn't vibrate and so on. Thanks ahead of time.
Factory GM mirrors will have less vibration issues than aftermarket and they will be level with the ground. Most aftermarket tow mirrors will be slightly tilted upwards and not be level (there is a mod you can do to get them close to level on the Duramax forum). And yes the mirrors are the same as previous years with the same body style (11-14 have the same frame and body).
2007.5 and newer will work on 2007.5-2014 2500hd/3500hd. Your dealer should be able to order you the GM accessories kit. Power heated replacement mirror tow mirror kit 19202235 is $460 for the pair. The power folding replacement kit 19243900 is $605 for the pair.
I live with the SLIGHT and I mean slight vibration of my aftermarket tow mirrors for the fact they were 168 shipped for the pair. It was only noticeable because I was expecting it and looking for it. I'm very happy with them
I bought my truck new in 2011 and I got the dealers to include the tow mirrors at no charge. Why would a dealer quibble about a $400 pair of mirrors that costs them $200 and possibly kill a deal on a truck that they will make a profit of thousands of dollars? When I got the truck the tow mirrors are installed and I was good to go.
my dealer refused on my new 11.... Fought me tooth and nail.... I settled for the slip on type and now that I have these I'm mad I never pushed that or even just bought them myself way better
Dealer fought you on ordering accessories? Are they wanting to sell trucks? I would have walked out and went to another dealer.
Sent from my LGL86C using Tapatalk
Take a look on Amazon.com, I was looking around about a month ago and they had them for my truck, heated, turn signals etc for 280 range. Do a search for Fit System 62093-94G, those are the ones listed for my truck.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
