Installing extra reverse lights, how to wire?
I'm wanting to hook up some additional lights under my rear bumper for extra reverse lights. I want them to come on only when in reverse. My thought is that I can just splice into the reverse wire at the taillight or trailer plug, put in an inline fuse and call it a day.
Would that work for what I'm going for? I'm not going to rigid lights or anything ha expensive, just some regular small oval or square lights. Something like these from Northern Tool. http://www.northerntool.com/shop/tools/product_200575885_200575885
We go camping and night fishing so backing up to the river with a little more light would be nice.
From some research it seems I have two solutions, both using the 7-pin connector at the rear of the truck.
Since the backup wire at the 7-pin is fused under the hood, can I simply splice the power wire from the lights into the reverse wire (light green) then ground the lights. I might have to add the fuse under the hood.
My second option is with a relay. Splice into the red power wire at the 7-pin to the relay (I think I would need to attach the red wire in the engine compartment to the fuse box stud and fuse it), relay to a ground, splice into the reverse light and run that to the relay, run wires from lights to relay and then ground the lights? If that sounds right I just need to know which pin on the relay each wire needs to go to.
Since the 7 pin output is made to power reverse lights on the trailer I would use that and no relay. Or upgrade to a rear camera they work pretty good at night
Sent from my SCH-I535 using Tapatalk
What I did for adding lights to my 2011 was install a junction box underneath the truck at the back. It is a 7 pin box. I purchased a reese T adapter and installed that. Basically it fits between your wiring harness and the 7 way plug, and gives you another set of wires coming off of that harness. I ran those to my junction box. Any lights I add, all go back to the junction box and are attached to the corresponding stud I am looking for. This way, all my wires hook up in one, sealed location. If I ever have a problem, I know where to look, and there is no splicing anywhere.
http://www.picocanada.com/en/product/990.php
  • 3 weeks later...
There is a kit out that can slide around ur hitch so it's still usable but it adds two oval lights, they can work on reverse or a switch on the side will turn them on anytime.
They are called White Knight. I had them on another truck I had and they work great! Especially when you have tinted taillight lenses.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
