Anyone unhappy with the 14 Silverado 6 speed transmission?
PMattras
I had a 1983 Chevy Silverado with the straight six and automatic with the overdrive. For the longest time the overdrive would pop out when you went up hills and go back in when your were going down hills. CT has a lot of hills. It drove me nuts for the longest time. As time went on, it got better and I kept the truck for 18 years until a deer took it out. I got what I paid for the truck from the insurance company plus the $1,000 rebate due to the gas tank issue. Great truck.
I will be using my truck mostly as a daily driver and the little time I used it, the shifting seems to be okay. I just don’t know how these new 8 or 10 speed transmissions are going to handle. Usually I get the low end truck so the update transmissions are usually offered later before the high end trucks get them. Maybe there will be fewer issues shifting with the V-8’s compare to V-6’s. The cost will go up and these truck prices are going out of sight.
Since the new 2014 Chevy Silverado all have the six speed transmissions, where do you feel the 8 or 10 speed transmission would have the greatest benefit for the normal users etc.? Is it worth the additional money? Problems? What are your complaints with the six speeds? I am happy with what I got so far.
Several threads covering this already with plenty of responses, complaints, etc... like you're looking for
Sorry.
How many miles do you have? The transmission needs some time to "learn" your driving habits. Give it some time if you dont have many miles.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
