Wider Tires
LTZTom
My truck has P275/55R20 tires on if from the factory. Does anybody know if I could get tires the same overall DIAMETER but a wider tread?
305/50/20? Using a Goodyear Eagle GT II, overall height is 32 inches, vs the 275/55/20 Eagle LS2 at 31.8 inches. Speedo would be off 0.5%, 60 mph with the stock tire would be 60.3 mph with the 305. Width is a tick above 1 inch wider overall.
295/50/20 also but there is only one choice on Tirerack.
Damn....nevermind... This guys beat me to it. ^^^^
Tom,
Below is some information. I don't have first hand experience with the stock wheel offset and larger tires but if your factory wheel is at least 8.5" wide and with a around a 30mm offset then you can run a 305 tire like I have listed below, it is almost exactly the same diameter at 3/10ths of a percent bigger which will have no adverse effect on Speedo or factory shift calibrations. I have 305's on mine and these aftermarket wheels are 30mm offset.
I'm sure that somebody that has more experience with the stock wheels will chime in shortly.
This is your stock size...
275/55R20
Imperial Metric
Section Width: 10.83 in 275.00 mm
Rim Diameter: 20 in 508 mm
Rim Width Range: 7.5 - 9.5 in
Overall Diameter: 31.91 in 810.50 mm
Sidewall Height: 5.95 in 151.25 mm
Radius: 15.95 in 405.25 mm
Circumference: 100.25 in 2,546.26 mm
Revs per Mile: 651.84/mi
Actual Speed: 62.14 mph 100.00 kph
Speed Variance: -
Diameter Variance: -
Here is an alternate size if wheel permits...
305/50R20 Imperial Metric
Section Width: 12.01 in 305.00 mm
Rim Width Range: 8.5 - 11 in
Overall Diameter: 32.01 in 813.00 mm
Sidewall Height: 6.00 in 152.50 mm
Radius: 16.00 in 406.50 mm
Circumference: 100.56 in 2,554.11 mm
Revs per Mile: 649.84/mi
Actual Speed: 62.33 mph 100.31 kph
Speed Variance: 0.31% too fast.
Diameter Variance: 0.31%
Tom,
275/55R20
Imperial Metric
Speed Variance: -
I'll have a look at yours when we get around to doing the tune. Thanks!!
FWIW I thought about doing this but decided against it for fear of rubbing. I ended up going with a more aggressive looking all terrain tire (Cooper Zeon LTZ) in the stock size. Glad I didn't I get a slight rub at full lock to the right only. Can't imagine it would be anything but worse with the 305s. I think it looks pretty decent compared to stock
Craig
I have 295/55r20 trail grappler, no rubbing5e3usa5e.jpg
I have 295/55r20 trail grappler, no rubbing5e3usa5e.jpg Sent from my iPhone using Tapatalk
are you leveled?
Yes sir, it's a rough country 2" level
Yes sir, it's a rough country 2" level Sent from my iPhone using Tapatalk
Gotcha, im sure that helps the clearance as well.
    btm
    btm
  • Who's Online   5 Members, 0 Anonymous, 1,504 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
