Power wagon
Stex
It's really neat what they've done with the Power Wagon. Honestly in trails and mud I bet it would easily outdo a Raptor. Lockers F/R, it probably is a crawling beast. I think they're idiots though for thinking someone buying a Power Wagon gives half a crap about fuel economy.
It'd be great to see GM do something similar, with the superior frame, it would be awesome.
I was on the 2005 Power Wagon press intro for the first "new gen" model. Most impressive. The 2014 Power Wagon is even sweeter. Tough to beat it off-pavement when you have factory lockers front/rear, the big Hemi, and so much suspension travel.
GM would do well if they could ever get past being so conservative in their pickup development thinking and offer a real off-road performance version of their trucks.
I agree, it really stands out and I can't recall anything like it in it's class. But removal of the tacky graphics is a must imo.
I was next to a ram 2500 the other day and I really liked it, and the fact that it didnt have lead springs was a surprise!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
