Keyless Entry System
I have a 2013 Sierra Work Truck and I want to change the settings so it doesn't chirp the horn when I remotely lock/unlock the truck.
Hello Therealjimm,
I understand that you have a question regarding changing the setting on the remote lock/unlock. I would be happy to research this question for you. Could you private message me including the vehicle's VIN?
Jennifer T.
GM Customer Care
Do you have the buttons to the left of the cluster? If not you can add them to gain access to that feature
This has got me wondering. Say someone needed to access that feature and borrowed a friends buttons to turn off the chirp. And when said buttons were unhooked/returned, would the change(s) made remain? Or would it return to stock settings?
I don't see why it wouldn't keep the settings.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
