It did make it sound better its a worth while project in my book noticed more power in mid range and better fuel economy
How loud is it compared to the stock with just magnaflow? I'd love for mine to be nice and loud.
  • 7 years later...
If you delete the cat's, use a spark plug defouler (just drill the center out to make the o2 sensor fits) screw the defouler into the exhaust pipe and screw the o2 sensor into that. It pulls the o2 sensor out of the pipe enough to read without throwing codes (guy at autozone told me this trick, worked will on my civic)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
