am I doing something wrong?
Update: we checked the Alternator Output, and its only putting out 13.4 Volts when the Headlights off, and only 12.95 Volts with the headlights on; it seems the Alternator is BARELY Keeping up on its Charging Duties. and and every once in a while if you rev the engine, it will backfire through the Throttle Body; it was found that Spark Plug Wire #5 is partially burned, and is suspected to be the cause of the Backfire.
  • Replies 35
If your ambitious, you could disassemble the alternator and try running some emory cloth over the copper that the brushes ride on. If the thing sat for a long time, they can tarnish up pretty good. Would be a good learning experience for the class too.
That may, or may not be the problem though - these days the electronics (and bearings) inside leave alot to be desired.
Also make sure the battery is in good condition and fully charged. As stupid as that sounds, to get the proper output result, the battery needs to be fully charged, and in good condition. Are you testing output at battery or at the alternator? You should also verify that the alt belt and pulley are clean and dry.
What is the voltage when you hold the engine at 2000rpm, both with and without a load on it?
^^^ +1 - simple stuff first.
We had the starter rebuilt, and it cranks a whole lot better; but we went ahead and put it on our shop's midtronics Battery/Starter/Alternator tester, and the new battery, and rebuilt starter passed with flying colors; guess what failed its test!
Sent to the Interwebs via a Bolt of Thunder
the voltage without a load was 13.78, and with a load, it was 13.18; it pretty much failed the test with Low Voltage. but its Not My Problem anymore, because the Owner Picked it up this afternoon!
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
