am I doing something wrong?
Was the bolt broken before the head was removed, or did it break while being removed? If bolt is below surface, and was already broken before head was removed, you may be able to use a sharp center punch and walk the remaining bolt out,
If it broke off on disassembly, you are going to need to drill and extract. Depending on you school auto shop's equipment, you may be in luck and have a way to mount the block in a milling machine and do the bolt removal with the milling machine. That way you know it is straight, and will be dead centre, and nothing will move off center.
The last thing you want to try is an ez out or any of those fluted hardened extractors. If the break off in there, good luck getting the hardened parts out.
You have an instructor there for a reason, take advantage of it.
  • Replies 35
That reminds me of the joy I had drilling an extractor out of a thermostat housing boss on a '81 Dodge Omni .... in the parking lot of my ghetto apartment complex in the city. Trust me - you don't want to go through that ...
..... nor do you want to live in a ghetto apartment complex. :D
By the time I was finished, the hole went from 1/4" to about 9/16" across. :lol: Once I finally got the bits of extractor and drill out of there, I stuck a Bic pen case in there about where I thought the hole was, and packed it full of epoxy putty. Next day, I ran a tap through the hole. I'll be damned if that thing didn't leak a DROP!
Then 3 days later, my girlfriend at the time pulled right out in front of someone and totalled it. I was upset because I used my best street signs for floorboards in that thing ...
another Update: the Remains of the Head Bolt are out! my instructor ended up welding a washer and a nut to the remains of the bolt, and it came out without a fight! and I also Learned some things that have been farmed out to Machine Shops. the Lost arts of Valve Grinding, and Valve Seat Grinding! Tomorrow, I will learn how to Lap Valves, and then the Reassembly can Begin!
If your shop class is anything like mine was, you saw the very basics of valve grinding. There is so much more when done in a well equipped shop. Lapping valves is one of those things that will actually show you something useful in its simplicity.
Did he not try to use a small punch and walk the broken part out? Sounds like the bolt was either flush with the deck, or slightly proud of it. He may have been able to weld the washer on edge to the bolt, then use the washer like a skate key to wind it out.
I actually have a picture of how he did it, but it will have to wait until I get home this afternoon.
Sent to the Interwebs via a Bolt of Thunder
  • 3 weeks later...
Another update, and another problem: its all back together (finding out where all the Accessory Braces go was a Nightmare!) but it won't start; I KNOW it has Spark, because Cap, Button, Wires, and Plugs are Brand new; i was VERY careful about putting it on TDC on #1, and when we shot some fuel down the Throttle Body, it actually hit a couple of times! there is no sound coming from the Fuel Pump, and we are testing the Fuel Pump Circuit for continuity. and more help is welcomed!
double check all your grounds..make sure their clean and tight..also new parts dose not mean good. recheck everything..
good luck
If it has throttle body, you should be able to see if fuel is being sprayed from the injector. Is there fuel coming out of the injector while cranking engine over? You should also have fuel pressure at the Schrader valve in the test port on the fuel line.
Changing ignition wires, cap and rotor does not mean you have spark. Pull a wire off of a plug, stick a screw driver in the end and hold it close to a ground spot and crank engine. You should see a spark.
good luck
an Update on that, the MAIN Fuel Pump Ground at the Tank was found to be Completely Severed! I'm already working on a Fix, and will Update Tomorrow!
Or considering this is a school, they probably have a spark tester. :lol:
Update: IT LIVES! had a bit of an issue with the Spark Plug Wires (my instructor thought I had installed the Distributor 180° out, but it turned out I was careful enough to install it CORRECTLY!) but as soon as it ran for a few seconds, old coolant and steam started pouring out of the tailpipe; we removed all of the spark plugs and cranked the engine over to see if there was any coolant going in the combustion chambers, and thankfully there wasn't any.
If the exhaust system had enough coolant in it to completely fill one section, that will make the truck hard to start initially. No exhaust flow, no where for the contents of the cylinder to go. You may find that simply taking the truck for a good run, with some WOT runs to clear the majority of the coolant out. Your muffler should have a small drain hole along the lower edge of the end of the muffler.
When I went to school, it was usually the newest student in the class that was the ignition lead tester. Most classmates knew enough to not fall for holding the plug end of the plug wire, but, not many would notice that the lead they were holding was the one off the cap from the coil. Depending on the status of the points(yes, that is how old I am, points and condensers in auto class at high school) just turning the key on would give a good jolt without the engine being cranked over.
well, we ran it for a while after Adjusting the Rocker Arms and Setting the Ignition Timing, it Runs BEAUTIFULLY, and the Exhaust cleared right up! but now the Oil Pressure Gauge and the Fuel Gauge are acting very erratic, the Fuel Gauge will bounce around, and the Oil Pressure Gauge is maxed out at Idle, but Drops to about 40 PSI when you run it up to about 2,000-3,000 RPM. (and there will be fresh Gas put in the Tank sometime Tomorrow, because the Exhaust Stank to High Heaven of Stale Gas.) also, after it ran for a while and we stopped the engine, it was hard to Restart and almost acted like the Battery was dead. (i myself think the Starter is getting Heat Soaked)
The gauges, senders, and wiring on these things going all the way back to the 80's certainly left alot to be desired. I'm having the same issue with the fuel gauge and temp gauge on our '89 S10 Blazer - everything was working fine until it sat 3 weeks. Figures, as I have it for sale. The S10 platform wasn't noted for it's superior quality, even when brand new ... so at age 25, this puppy is hurtin'.
Could be any one of the 3 - but I'd check the wiring first.
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
