I found this picture. This is the ps of the motor. One can for the hose that goes to the TB and another can for the long hose on the ds.
Edited by kstruckcountry
Debadged the tailgate today. I'm glad the tail lights were free because I don't think I like them all that well. Probably buy new stock ones at some point.
Edited by Daryl Z71
Catch can goes on driver side port.
You sure?
That is the dirty side. And every one i have seen has it there.
That's where I had mine on the 2011 Silverado. Wasn't sure if it was the same on this 2006 or not.
The truck is looking real nice. As to the Airiad: I'm seeing them listed at about $140.00 for what looks to be simply a plastic tube.
What kind of performance gains do you expect from it?
Thanks! Yep, the tube was $140. I'm not expecting anything major from it alone, but when I have my tune done along with this MIT, and my Headers I'm expecting some performance gains then. Edited by Daryl Z71
So today I installed my wiring kit from LMC Truck for the 4hi headlight mod.
Before
After
Before
After
If i knew you were looking, i could have sent you mine.
Before
After
What's the benefit of doing it this way? I simply ran diodes in the fuse block from the hot of the hi beam relay to the hot of the low beam relay
The relay is the proper way. This way the connection is fuse and the bulk of the power runs through the relay. Diodes will get hot and can burn up. I say that but i am currently using a diode right now. I dont remember why i pulled the relay
