Electric Fan Install Question
I am thinking about installing a flex-a-lite 295 in my GMC.  I was looking at the install instructions online and they said:
Locate the two wires that go into the a/c compressor, and determine which wire activates the clutch compressor when
the AC is turned on, this is your signal wire. If the signal wire sends a positive signal, put a splice tap on the
positive signal wire with the green wire running back to the VSC, and connect to terminal #8. If the signal
wire is negative, then connect to terminal #7. Do not connect both wires to VSC. Only one wire is used to
signal the VSC.
Question is how do I figure out which wire is the signal wire and how do I figure out if it is - or +?  I am assuming I will need a multimeter for this.
Holder;
 It's easy....get a 12V light (continuity tester for $2 @ auto parts).  Ground the clip to the - on your battery and then probe the potentially hot 12V leg.  If the light lights up?  You got it...if not?  Switch the clip on your test light to the + battery terminal...that way when your probe hits a ground leg it will light the light.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
