2013 captiva no power
sirdon
Hello I purchased my GM certified 2013 Captiva in Jan 2014. Since the end of March the car randomly disengages all power and will not start or open. I towed the car to a dealership in Illinois they tested it for fours days couldn't find the issue and returned the vehicle to me. after 1 day the same issue occurred and kept reoccurring almost everyday. I brought the car back they had it for 5 days a...nd saw and replicated the problem, ( I showed them by hitting the fuse block the power returns)they replaced the ECM module and returned the car to me after a day and half the no power issue returned. I talked to Brenda at Chevy customer service x21566 I am dropping off the car again this Thursday. I am including a link video of the most recent no power issue from Sunday, any help you can give would be appreciated. I have a family member in the cancer center since April 4th and need a reliable car to travel to the hospital this is my third chevy in 5 years. I have never had an issue like this! Please help
Make sure they get to watch the video as well. It will not help them diagnose it properly, but will show that what you are saying is what is happening.
What you have is an open circuit somewhere. I would really hope that someone has already taken the battery cables off and cleaned them, the put them back on securely. But, from the looks in the video, the cables look clean, and sometimes people just look at it and say, 'looks clean, must not be it', and never actually take them off and clean them.
If the problem in the fuse block(or holder), you should be able to unclip the entire assembly and see underneath it. If you want to bother, try lifting it up, flip it over, and check all the big wires to ensure they are firmly attached. You may also want to follow the battery cables to the next attachment point and verify connection is clean and tight.
im sorry but its not your problem to fix your car ,,,id return it for another ,,,that is one quirk of a certified GM used car
demand it ,,,enough is enough
thoughts for your family member ,,,,,
Those are just weird. Only fleets can get new ones and all of those leftover Saturn parts scare me
I agree with demanding on fixing it. If it looses all power( more than once) and it won't start. Then it can loose power while you are driving it. And I am sure you are aware of what happens when that occurs. Sames as all those units that are being recalled for ignition switches. Not a pleasant thought in my opinion.
that UBEC almost looks the same as the UBEC they used in the Aveos; there is a terminal in the Bottom Right Corner which is where the UBEC gets its Power From; make sure that 10mm Nut is Clean and Tight. if that is not the problem, unclip the UBEC from its Base, and make sure all of the connectors are clean and tight underneath (there's 3 Large Connectors, and a Small one.)
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
