difference in rear height
I didn't measure before I installed my 3" rear blocks but after The driver side is like .75" lower then the passenger side. Is this because of the gas tank on driver side? anyone seen that much difference between the two sides?
Thanks for the input.
Yes Tank is full, and tire presure is the same on both sides.
Just thought it was strange to be that different.
Thanks
No vehicle sits perfectly level even from the factory.
Gas weights about 6 lbs per gallon so if your tank is full that's about 205 lbs on that side.
Thats kinda what I was thinking. Thank you
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
