Yup - I have the exact same prob
no lane assist & beeping instead of vibrate ...
and front collision beeps instead of vibrate ...
and DIC warning
You know it would seem like they would have this system worked out by now than they do. I mean they've been putting it in other GM vehicles for years!
Only wish I had a DIC warning warning. They told me if I had some sort of warning then they would know what to fix.
I get the haptic feedback and/or the beep when I'm parking (depending on which one I've got turned on) but I've never got anything as far as the Collision Warning system or the lane keep assist or Lane Drift, flying to the moon, or whatever the heck they want pretend like it is.[emoji37]
Sent from my SAMSUNG-SM-G935A using Tapatalk
Took my truck in for the Driver Assist Service Warning (beep instead of shake) issue.
They replaced the haptic motor actuators referenced earlier in this thread and it appears to work fine now.
Had my Drivers Seat Actuator (84017512) left side done yesterday (list price was $48.08) No Charge under warranty.
In 90 minutes they did:
seat actuator
tire location re-learn
Brake peddle bolt re-call
Radio reprogram to lower the loudness of the ding warning (TIS2Web) (40 minute download)
All Good
seat actuator
All Good
'I went back to the dealer today, last visit they replaced the divers left side vibrate thing ... 5 days later the right side stopped vibrating ... so this visit the replace BOTH vibrate things .. . under warranty
  • 6 months later...
Just now getting my seatbelt recall done and they said the noticed a frayed wire regarding the lane departure warning
They said my invoice will have part numbers and want to charge $200 or so to replace it (seems I just rolled over my 12k mile CPO warranty by a couple miles or so)
Since its frayed I'll put electrical tape or a wire sheeth over it and hope it doesn't short out here
Edit Part number 22884702
Edited by awright2009
  • 7 months later...
Just dropped my 2015 denali. How the hell is a known issue not covered? 110 diag. Fee and they say part is 560 for a posible broken wire. Truck only has 24000 miles on its been back to dealer 4 times prior, transmission,seats etc etc. Sorry GMC/GM time to move on
  • 3 months later...
Sorry for replying late, i faced this problem and i fixed it by doing the correct diagnostic.
So firstly, i switched on my truck and start riding with the lane departure warning system is activated. Then i turn right i felt the vibration, next, i turned left and suddenly the vibrate alert turned into sound alert.
then i removed the seat cover and checked the vibrate motor i found that the harness was cut i pick it out, reconnect and elongated the wore and reinstall it.
so its working fine.
  • 8 months later...
Im encountering the same issue with my GMC Yukon 2015, the message driver assist system appear intermittently , I had visited a specialized technician and found nothing , next day morning the same message appeared once again and don't no what to do , the car not under warranty and if I send it to dealer they will charge me a lot , I will try to send it back to the same technician and advice to check the wiring for the haptic sensor under the seat and I will see what he will answer.
I'm reading this several years later and I'm thinking my 2015 Suburban must have the same problem. The info screen is saying service Driver assist, but I still get the beeps and the vibrations. I know the heated and cooled seats had to be repaired so I'm assuming the wires got jacked up. Thank you for the part numbers....if chevy has kept them the same!
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
