Yup - I have the exact same prob
no lane assist & beeping instead of vibrate ...
and front collision beeps instead of vibrate ...
and DIC warning
You know it would seem like they would have this system worked out by now than they do. I mean they've been putting it in other GM vehicles for years!
Only wish I had a DIC warning warning. They told me if I had some sort of warning then they would know what to fix.
I get the haptic feedback and/or the beep when I'm parking (depending on which one I've got turned on) but I've never got anything as far as the Collision Warning system or the lane keep assist or Lane Drift, flying to the moon, or whatever the heck they want pretend like it is.[emoji37]
Sent from my SAMSUNG-SM-G935A using Tapatalk
  • 3 weeks later...
Took my truck in for the Driver Assist Service Warning (beep instead of shake) issue.
They replaced the haptic motor actuators referenced earlier in this thread and it appears to work fine now.
Had my Drivers Seat Actuator (84017512) left side done yesterday (list price was $48.08) No Charge under warranty.
In 90 minutes they did:
seat actuator
tire location re-learn
Brake peddle bolt re-call
Radio reprogram to lower the loudness of the ding warning (TIS2Web) (40 minute download)
All Good
  • 3 weeks later...
seat actuator
All Good
'I went back to the dealer today, last visit they replaced the divers left side vibrate thing ... 5 days later the right side stopped vibrating ... so this visit the replace BOTH vibrate things .. . under warranty
  • 6 months later...
Just now getting my seatbelt recall done and they said the noticed a frayed wire regarding the lane departure warning
They said my invoice will have part numbers and want to charge $200 or so to replace it (seems I just rolled over my 12k mile CPO warranty by a couple miles or so)
Since its frayed I'll put electrical tape or a wire sheeth over it and hope it doesn't short out here
Edit Part number 22884702
Edited by awright2009
  • 7 months later...
  • 1 year later...
Just dropped my 2015 denali. How the hell is a known issue not covered? 110 diag. Fee and they say part is 560 for a posible broken wire. Truck only has 24000 miles on its been back to dealer 4 times prior, transmission,seats etc etc. Sorry GMC/GM time to move on
  • 3 months later...
Sorry for replying late, i faced this problem and i fixed it by doing the correct diagnostic.
So firstly, i switched on my truck and start riding with the lane departure warning system is activated. Then i turn right i felt the vibration, next, i turned left and suddenly the vibrate alert turned into sound alert.
then i removed the seat cover and checked the vibrate motor i found that the harness was cut i pick it out, reconnect and elongated the wore and reinstall it.
so its working fine.
  • 8 months later...
Im encountering the same issue with my GMC Yukon 2015, the message driver assist system appear intermittently , I had visited a specialized technician and found nothing , next day morning the same message appeared once again and don't no what to do , the car not under warranty and if I send it to dealer they will charge me a lot , I will try to send it back to the same technician and advice to check the wiring for the haptic sensor under the seat and I will see what he will answer.
  • 1 year later...
I'm reading this several years later and I'm thinking my 2015 Suburban must have the same problem. The info screen is saying service Driver assist, but I still get the beeps and the vibrations. I know the heated and cooled seats had to be repaired so I'm assuming the wires got jacked up. Thank you for the part numbers....if chevy has kept them the same!
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
