New Virus
patrick
One of the guys at work got it at home. Said it killed his OS.
Thanks for the warning!  :D
I hate viruses(but that doesn't stop people from sending them to me) :angry:
It say to download for the version of IE that you have.  It shows the updates for IE 5.5 SP1 and IE 5.01 SP1.  I have IE 6.0.  I'm assuming I don't need this, is that true?
norton should catch it if you have the latest version, but they posted removal instructions also:
1. Run LiveUpdate to make sure that you have the most recent virus definitions.
2. Locate the line that begins with Shell= in c:\windows\system.ini. Remove all text following Explorer.exe from this line. When finished the line should look like:
shell=Explorer.exe
Note: If Windows is installed in a different location, make the appropriate substitution. Also, some computers may have an entry other than Explorer.exe after shell=. If this is the case and you are running an alternative Windows shell, then change this line to shell=Explorer.exe for now. You can change it back to your preferred shell after you have finished this procedure.
3. If AutoProtect is not enabled, enable it before restarting the computer. For instruction on how to do this please read the document How to enable and disable NortonAntiVirus Auto-Protect.
4. Restart the computer.
5. Start Norton AntiVirus (NAV), and make sure that NAV is configured to scan all files. For instruction on how to do this, read the document How to configure Norton AntiVirus to scan all files.
6. Scan your system with NAV. For instruction on how to run a scan with NAV, please read the document: How to scan for viruses.
7. For each file detected as infected by W32.Nimda.A@mm or W32.Nimda.A@mm (html), choose Repair.
8. For each file detected as infected by W32.Nimda.A@mm (dr), W32.Nimda.enc, W32.Nimda.A@mm (dll), choose Delete.
9. Restore admin.dll and riched20.dll from backup or the Windows/Office .cab files if necessary.
10. Remove unnecessary shares.
11. Delete the guest account from the Administrators group (if applicable).
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
