2001 1500 HD, 6.0 Vortec with 225K. This truck has gotten hard to start when it is cold. Takes about 2-3 crank attempts of 2-3 seconds to crank. I have tried an extended crank of 5-8 seconds and it still will not start on the first attempt. Most of the time when it is warm it starts first time everytime. This just started a few weeks ago and nothing on the vehicle has changed.
I am currently on vacation and do not have my scanner with me, however the scanner at oreilly's did not pull any codes. I am concerned that it could be a fuel pump. I just hanged the fuel filter last week thinking that it could be restricting fuel flow and causing the problem. It made no change at all. Once the engine is started, everything seems normal, no loss in power, no skipping, no rough running, nothing.
That said, is there any suggestions on what the issue could be other than a weak fuel pump or ideas that I can start to look at before I get the truck back home. Any help is appreciated.
Thanks
Yup sounds like the fuel pump is on its way out. When the motor is cold due to sitting the fuel pump has lost all pressure and takes a few more longer cranks to build pressure once pressure is there it starts now when the motor is warm there is still some pressure in there due to the motor just being ran as it doesn't take as much pressure to start the motor is the reason it starts when warm.
Fuel pressure should be at 55-62 psi while the pump is running
Do your self a favor and don't skimp on a cheap pump cause with those you will be back in there in no time soon.
Edited by Silverado4x4
When starting cold, try turning key on, let the pump prime, then key off. Then key on,start. See if it helps while you're on your trip. But, it's probably pump time
Edited by txab
I may go by a local shop here on the island and see if by chance I can borrow their fuel pressure test gauge for 10 minutes to verify. I know that fuel pumps usually just die. I do not want it to die while I am out of town or on my way back home.
Does anyone on this forum happen to like on Amelia Island Florida?
Fuel pumps don't always just die. The symptoms you are explaining leads me to believe 1 of 2 things. The fuel sending unit, and/or the fuel pressure regulator.
Colossus, please explain... I know the sending unit is sketchy as is has been reading inaccurately for quite some time, like maybe a year. It will read correct and then fall to nothing, many times like a ping pong ball, back and forth....
How would I diagnose between the regulator and the pump itself?
I just put in a new battery and it seems to have removed my cold start issues. I've been needing to double crank when the engine is cold: overnight, all day at work, etc. But as of Saturday she fires up right away.
I doubt it'll remove my cold temp issues related to the intake manifold gasket but its one less thing to worry about.
+1. Regulator was my first thought due to being cheaper. Had a 2k that did the same thing. Warm(er) starts, just fine. If it sat for a while (maybe 2-3+ hrs), crank a few, crank some more a few, crank a bit more, and would start.
Good luck!
What I mean by the sending unit is the whole module in the fuel tank. The sending unit (aka the pump) the float (fuel level) and filter (if it does not have an external fuel filter, it is in the tank) Replace the whole thing which would be all those things. In the GMT-800s, they were known to go out between 60,000-100,000 miles, and the ones they were replaced with would last just about as long. However, when the pump goes out, it won't always just suddenly go bad. Sometimes it does, but most of the time it will give you a hard starting symptom like you were describing. I had an old 99 GMT-800 that more or less did what yours is doing. I would have to turn it to the on position for a few seconds to prime the pump, then turn it off, then back to on position a few seconds, then off, then on again, then turn to start, and it would start. But even that only worked for awhile before it got worse and I had to have it replaced. The FPR (fuel pressure regulator) were also very prone to leaking and failures on the GMT-800s too.
I follow you now. I know it is an entire assembly as I have replaced several and once already on this truck. You just threw me when you mentioned sending unit...
Because there is no lack of power and no issue at all once it is running, I think the actual problem may be the regulator. However, due to the fact that the float sensor is erratic and not working most of the time, I will likely replace both...
I just wish I could replace the regulator before heading home, I do not want to get stranded.
If your 6.0 is like my 5.3, the FPR will be on the drivers side fuel rail on top of the valve covers. It could easily be a 1 minute job and all you need are your hands.
Edited by white1500
thanks white. I was looking at it today and thinking that at wort I would need a flat-head screwdriver to pry off the keeper. But looking at the kit that it comes with the keeper and a C-spring clip, I was afraid that I might need need-nose pliers of even retaining ring pliers. I have all the tools in the world at home, so I would not want to buy duplicates of something i already have...
Im betting its the pump. Mine did exact same thing two years ago. Went on for about a month before the pump finally crashed. Had the new pump installed ($900 buck repair) mechanic recommended the OEM pump, and guess what. It has started doing the same thing now. I guess these pumps are just no good. I wish I could install an outside the tank pump.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
