new tires
jmontz32
I searched all of the forums and cant find a yes or no answer to this question. I know 275/65r20 will fit with the rough country 2.5 inch leveing kit but I have the 2 inch kit....does anyone know if 265/75r20 toyo mts will fit???? Truck has 9000 miles and already had a flat in one tire and another tire that os struggling to hold air pressure with the stock continental ecos that were put on my truck. Please advise.
My personal opinion is no that wouldn't work without trimming.
LT275/65r20 is 34.5 x 11
Pretty sure TX_AT is running those on a 2.5 and he said they rub but he didn't trim. Which honestly I'm suprised at that. So I'd think 2" would be worse.
10-4. Ill go with 275/60ar20 then. Will have to switch to the ATII tires instead of the m/ts.
Let us know how these end up fitting etc. I'm interested in finding a set of 20's with a little more rubber to them without having to get a lift as well
If you're switching to At2 look at the 285/55r20 or 295/55r20. Those are Xtreme sizes so you'll get close to the MT look.
So the width of the 285/55...I wonder if those would fit okay? Ive seen the xtremes before, I do rather the look!
If you have a 2.5 RC level both the 285/55 and 295/55 should fit as long you don't deviate too much from factory offset on your wheels. I've seen a bunch people on this and other forums run that set-up with AT2 Xtremes.
  • 1 month later...
Ended up going with the 285/55R20 ATII Xtremes. I have the 2" RC kit and there is a slight rub at full lock but nothing to be concerned about. I absolutely love the tires, so much better than those stock Continentals Ecoboosts.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 322 Guests (See full list)
