Happy Birthday
k1500chevy97
Time to pick up a pack of Marlboros and some "good books"   :D
While you're at it, might as well pick up a rifle as well!!!  Congrats dude, I remember what it was like when I turned 18...wait, that night is a total blurr now that I think of it!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
