Leaving kit
Only if your dealer is able to prove that the leveling kit caused the failure of the part you're trying to get fixed under warranty.
You can do anything you want to your truck, but like said above, if what you did is a direct result of something braking then you are responsible for the cost of fixing it. Depending on the dealership you might be in for fight.
