Improved braking
Has anyone done stainless brake lines or other brake up grades?
Factory lines are nylon coated. Been since 2007 body style. I have never seen a rusty brake line on a 2007 or newer truck. The frames, suspension, etc? Yes
I think the OP is looking for performance upgrades, not really rust prevention. SS lines generally reduce flex and can improve pedal feel. I'm not sure anyone here has done this yet however.
Looking into brake upgrade myself since going bigger in tire size. Haven't looked much into it though. Definitely noticed the longer stop times after wheel and tire upgrade.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Want better stopping distance/brake fade? Get a decent set of drilled/slotted rotors and pads. Less unsprung weight too.
Stainless lines will slightly improve the pedal feel, but they won't improve the stopping. The OEM pads are made to last a long time and limit the amount of brake dust they put out. Performance pads will stop the truck much better, but you can expect some additional dusting and quicker wear. Drilled and slotted rotors are for bling, they don't provide any additional stopping power and, unless you're buying Porsche quality rotors, drilled rotors will crack long before plain or slotted rotors.
Was looking for better pedal feel. My V has SS brake likes (14" Brembo rotors and pads) and then going to the Ranger sometimes I feel like it won't stop. I want to try to avoid that uneasy feeling hard braking gives me in my current step up.
Its a 6000 lb brick in the wind. You're never gonna get it to stop like your CTS-V
It CAN be made much better. A set of performance pads/rotors can go a LOOOONG way, especially when coupled with better calipers. Stickier tires help a lot too, but you'll give up tread life. Pirelli makes some really nice performance tires for SUVs. They'll work on a truck too.
We are never going to get our pickups to feel like our track cars. At least not on any budget I'm willing to spend on a pickup. :rolleyes:
Check the rear brakes. The Ranger brake shoes are known for the friction material detaching from the metal bit and it won't make noise but the second the drum comes off the linings fall out. If they're in good shape, check the adjusters, you may be able to dial it in a bit more to firm up the pedal.
Then I suggest a trip to AutoZone for some chi-com parts.
Your brakes are your life.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,276 Guests (See full list)
