Cigarette lighter not working
Neufy16
I just got a truck
2012 GMC Sierra Nevada edition 1500.
Neither cigarette lighter is working, I've tried 3 separate chargers.
I've checked all fuses in the cab and the one labeled "LTR" under the hood (number 53(20A))
All fuses are alright, any help would be wonderful
Have you checked to see if you have voltage to the sockets?
I'm not sure what you mean?
I used several differant chargers that work on different vehicles and theres no power
He means, did you check the sockets with a volt/ohm meter
Did you try with the key on?
The first thing you do is check the sockets and see if you have voltage with a volt/ohm meter or a test light. If you don't have voltage st the socket then check and see if you have voltage a the fuse. Just because the fuse is good doesn't mean you have voltage to it.
