2017 here service 4wd allmost every key start or soon thereafter.
dismiss message, everything works just fine.
I'll wait to drive an hour to dealer until something is really wrong.
have you ever figured this out on yours?
Yes it was a pushed out connector on the harness.
Ugghh, figures. They've already replaced the harness on mine and its still doing it.
I will say, mine doesn't happen every keystroke, it waits about every 2 to 3 weeks before it decides to come on once I dismiss it
Thanks
Edited by T_ClarkEx39
Thanks
also had problems with the 110v  port in console, also a pin problem in the same harness connector.
I will have to check that out. I never use that 110 volt port so it may or may not be working I wouldn't know
  • 10 months later...
Got this message a few times this morning on my 2016 with 25k miles.
Didn’t seem to have any issues attempting to change between 2 and 4WD....
  • 5 months later...
  • 4 years later...
I have a 2015 GMC Sierra 4wd with 244,000 miles. Over the years I’ve had the service 4wd message. I’d dismiss it and all is fine. Last night it came back I dismissed it and tried selecting 2wd or 4wd and it won’t do anything. I suspect a low battery because everything was acting different with the transmission. Wouldn’t go in gear forward or reverse, after several attempts it went in drive. After charging overnight everything seemed fine except transfer case wouldn’t move out of Auto position. Anyone else notice these batteries only last about 3 years?
Before I replaced my battery, when it would run out of "juice" and I did a scan, all kinds of errors ere present.
The MyChevy app would tell me every system needed attention.
I found I had a battery drain with my Dash Cam, once I got it sorted, no issues, the old battery might have been good all along.
Most batteries should easily last 5 years or better if you don't have a parasitic power drain somewhere.
Any idea where the X-1 TCCM connector is located. I can read the Service Bulletin, but there's no pics.
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
