Hey, I have a 2014 silverado LT z71, love the truck, but have a question. Seems about every 200 miles I get a service 4wd message on the dash. I have a service appointment next week to look at that, and for the recall about 4wd going into neutral. Has any other members had a service 4wd message on there dash, and what was the fix? Thanks and happy 4th
Had one right after they did the transfer case recall. It came on after getting above 35 mph and would not reset. They reflashed the recall software and haven't seen it since. Maybe the recall will fix your problem?
Hello skeeterzx
My apologies to hear that you have concerns with your service message for the 4WD frequently reappearing. Have you mentioned this to your dealership previously? Please keep us updated on what your dealership says!
Best,
Andraya
GM Customer Care
Was able to get to the dealer today to have 4wd drive message looked at and to do the two recalls. The tech called me and said they could not duplicate the problem, but it did show a code where it has been happen, he didn't think the reflash of the transfer case recall would fix the problem since the code was still stored afterwards, but he said to drive it and see, and bring it back if it happens again. I will talk to the tech when I pick my truck up in the morning. Hope they can get it worked out, going to OBX at the end of the month and will be using 4wd on the beach.
  • 4 weeks later...
Dropped truck off at the dealer again today for the same problem. The tech called me and said they were gonna keep my truck a few days and try and track the codes that have been stored. He did say they were gonna crack my transfer case open :( and see if they can see something in there. Other than that the truck is perfect and the dealer is good, just hate to have to keep taking my truck back to have it looked at.
I have exactly the same problem !!!!!! Everything was fine until I got the recall notice, had the software update for the so called "Transfer case shifting into neutral" notice.
The very next day the "Service 4 wheel drive messages" started. I can dismiss the message but every few days it reappears. The four wheel drive seems to work fine so I'm not going back to the garage again so they can screw something else up.
The truck only has 800 miles on it so I'm going to wait until I accumulate 3 or 4 more recalls so I can get everything done at the same time. I've already gone through 2 recalls and that's enough for now. I have other things to do besides wasting time at the dealers.
I'm getting the same message and I only have 800 miles on the truck so I don't really want them taking it apart unless they are sure of the problem. I just keep dismissing the message until someone realizes that it's probably a software glitch because everything was fine until they flashed the module during the latest recall campaign.
Just got my truck back from dealer today, tech said it was throwing code c0392, gm tech services had them drive it 150 miles in auto 4wd to set the transfer case clutches, I really doubt that's the problem as I have used 4wd on the beach before so they should have been set. I get the service message every 100-200 miles, so we will see what happens.
Other than the "Service 4 wheel drive message" is the truck able to operate in both auto and 4 wheel drive ?
Poster Chuck mentioned that he had the same problem and it was solved by reflashing the software so that's why I'm going to wait a while before bringing it back to the dealer. Once enough owners experience the same problem GM may know what to do. It's too much of a coincidence that a few of us are having the exact same problem.
It won't shift into 4wd when the light is on, but if I cut off the engine and wait 10 mins, crank back up and shifts into 4wd fine.
That's exactly what mine does.
If I try to shift it into auto or 4 Hi while the message "Service 4 wheel drive" is showing, nothing works. I then have to dismiss the message, turn the engine off, wait 10 or 20 mins for everything to reset and it runs fine for a few days until I get the message again.
But...... if I simply dismiss the message as soon as it appears, everything works just fine.
And to think that everything was working well until I brought it in for the recall is what really upsets me. Somehow they managed to screw something up that was probably ok in the first place.
Hey guys... ask your tech how many of this recall the dealership has completed. The reason I say this is that the technician that did mine revealed that he missed one of the final steps and it caused this problem. If they don't follow the tech bulletin verbatim it can cause this problem... good luck!
Thanks for the heads up but at my dealership the only person that you have any contact with is the "service advisor" behind the counter in the garage area. This person writes down the details, fills out the work order and passes it on to the technician. Now for me to suggest to them that perhaps somehow through their own incompetence they managed to muck up a perfectly good truck would be a bit of a hassle.
I have a 5 year warranty with roadside assistance so if the 4 wheel drive ever does leave me stranded I'll simply phone and have them come for the truck.
I'm definitely not going back to the dealer and have them rip out the transmission (as they suggested to skeeter) looking for a defect that most likely does not exist.
Meanwhile it only takes a second to ignore & dismiss the message.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
