2017 here service 4wd allmost every key start or soon thereafter.
dismiss message, everything works just fine.
I'll wait to drive an hour to dealer until something is really wrong.
have you ever figured this out on yours?
Yes it was a pushed out connector on the harness.
Ugghh, figures. They've already replaced the harness on mine and its still doing it.
I will say, mine doesn't happen every keystroke, it waits about every 2 to 3 weeks before it decides to come on once I dismiss it
Thanks
Edited by T_ClarkEx39
Thanks
also had problems with the 110v  port in console, also a pin problem in the same harness connector.
I will have to check that out. I never use that 110 volt port so it may or may not be working I wouldn't know
  • 10 months later...
Got this message a few times this morning on my 2016 with 25k miles.
Didn’t seem to have any issues attempting to change between 2 and 4WD....
  • 5 months later...
  • 4 years later...
I have a 2015 GMC Sierra 4wd with 244,000 miles. Over the years I’ve had the service 4wd message. I’d dismiss it and all is fine. Last night it came back I dismissed it and tried selecting 2wd or 4wd and it won’t do anything. I suspect a low battery because everything was acting different with the transmission. Wouldn’t go in gear forward or reverse, after several attempts it went in drive. After charging overnight everything seemed fine except transfer case wouldn’t move out of Auto position. Anyone else notice these batteries only last about 3 years?
Before I replaced my battery, when it would run out of "juice" and I did a scan, all kinds of errors ere present.
The MyChevy app would tell me every system needed attention.
I found I had a battery drain with my Dash Cam, once I got it sorted, no issues, the old battery might have been good all along.
Most batteries should easily last 5 years or better if you don't have a parasitic power drain somewhere.
Any idea where the X-1 TCCM connector is located. I can read the Service Bulletin, but there's no pics.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
