Lets talk fog lights
Noticed I have a bulb out. Like most of you, I get the "when it breaks, replace it with something better" frame of mind going :)
5202 bulb. Seems like a few options, stock bulb, LED or hid upgrade.
Hid seems like more then I want to spend.
LED seemed like a good choice, but after reading some reviews, seems like many are unhappy with the leds. Seems like it doesnt focus the light like the stock bulb and just tosses it out like a flood light. Probably not what I want to do.
What about these Projector type leds?
http://www.ebay.ca/itm/2pcs-HID-White-H16-5202-CREE-COB-LED-Projector-Bulbs-For-Fog-Daytime-Lights-/291162507567?pt=Motors_Car_Truck_Parts_Accessories&hash=item43caa3492f&vxp=mtr&_uhb=1
Any other options I missed? Thoughts?
The foglights with the 24 watt 5202 lamp are garbage. The lamp is rated 500 lumens. The LED you link to are rated about the same so I don't think it will do much to improve the situation. I did replace mine with 35W HIDs and adjust not to blind oncoming drivers.
Our 2010 Jeep uses a 45W halogen lamp in the fogs and they are great. Unfortunately most all manufacturers have now switched to the 24W lamp because they can use cheaper all plastic housings.
I'd go with HIDs. You could probably get the kit on ebay for $30/shipped. That would put out the most light.
LEDs are nice and they are almost getting to the point where they will be useful for a foglamp application. But, for now, they only look nice and don't really put out the focused beam of light that you'd want. I put in a projector fog bulb in my car and the light color is nice but you can't even tell when I put them on from inside the car. Pretty damn useless. :(
I pulled my housings out and installed 55w KC 57 series fogs in their place. I tried many different aftermarket bulbs. The brighter you get, the less the light pattern actually puts light on the road.
and I was disappointed lol.
One bulb came broken. the filament inside was busted off. So back they're going to amazon.
25w 5000k HID kit ordered.
You mean 35w right?
I have that kit in the fogs on my Denali and it puts out an insane amount of light. The other thing that helped was putting in new fog housings. I got a good deal on a set on ebay. Initially I got them for aesthetic reasons but the light output change was incredible. The old housings had serious chrome contamination and that wasn't reflecting the light outwards as designed.
Huh... didn't realize they make 25w kits now too. Very interesting. Throw up pics when you get them. Hopefully they have the light output you're looking for.
Will do!
Although I have to get in touch with the company today. The tracking # they gave me shows the lights shipped to San Francisco and someone signed for them. I assume they sent me the wrong tracking # as I'm no where near SF LOL
    needafix
    needafix
  • Who's Online   4 Members, 0 Anonymous, 553 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
