Trans question
So I decided to check my tranny fluid today, completely cold, last time I drove it was yesterday. So I started the truck and checked my fluid. It was between the bottom of the hot mark and the top of the cold mark. Is this bad? I know it's not GREAT so how can I drain the excess fluid? A syringe down the dipstick tube? Or is there a drain where I can just loosen it a little. It's a 05 6.0l by the way. I had to change my trans cooler lines in February and I may have put a little too much fluid in. Truck drives fine.
Check it when it's hot
I went for a drive, 20 minutes of easy in town driving. Here is a pic of the dipstick, I marked where the hot and cold marks are, and where the level was when I checked it. e3ymenag.jpg
So it is a little on the high side.
is the oil arrated ?
You mean have bubbles in it/ foamy? No, it still is red in color and has no hint of any burning smells, so I think it'd be fine. I mean if there was a surplus of oil it would be spit out of the breather.
if its overfilled ,it'll barf out the breather ,,,,,
drive it ,,,relax ,all good ,,,
it wont be burning smell unless the clutches are toast
