Rear end gears
Yes you can change it. If gm does it, it should not void the warranty. You should still have a warranty anyways. EX your speaker stops working, they wont say "we cant replace this because of the rear end gears". Just change the ring and pinion. The dealer wont know anyways about you changing the gear unless you blow the rear end AND the computer will need to be calibrated for 3.73's. So then you may as well get the BB tune
I asked the salesman and he told me that I need to get the heavy duty rear end that you can't just swap the gears out is that correct?
100% FALSE
100% FALSE
We'll I'm glad.
So my main reason for doing this is I plan in pulling a trailer lot more I feel like it will help with towing.
So basically get gears swapped and then I got to get a tune?
No. But you have the 6 speed so it will not be that horrible. Besides the tune will help with mpg so there will be a very small difference if any. And in the city you will gain mpg
Contact justin from blackbear. He is on here. Purchase the autocal record driving, email him files, he tunes, emails it, then you upload to truck. So it is a handheld
Also don't forget if you are 4wd you will need gear for both diffs. As said though you will have to be re-tuned to get the new gears to work correctly.
100% FALSE
Well, I dont know if there are gear sets available for the standard rear differentials yet. Right now the 3.73s only come in trucks with the tow package that has the beefed up rear diff.
Havent seen many people swapping out their 3.42 gears for lower ones yet. Maybe tho
    250.3k
    Old Bay
    Old Bay
  • Who's Online   1 Member, 0 Anonymous, 691 Guests (See full list)
