02 serria 4.8 spins but no fire
Robby1959
my serria 4.8 188 k miles started and died when put into gear now it just spins no sputter or trying to star = ran fine before . timing chain stock
no codes set , it just spins over , no sputter etc . I fuel pump was changed once ran perfect
well you were correct - a friend turned it over while I pushed the shradder valve on the fuel rail - just a trickle . pump replaced now the tail lights do not work uuugghh . the most likely popped a connector when removing the tank
Does anyone know where the plug is to the rear lights only my third working no brakes turn etc . [ she's blank ]
  • 4 weeks later...
