Mbrp cat back
  • Replies 35
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
I ordered the MBRP Aluminium kit for my RCSB to have it Ceramic coated inside and out but when I opened the box Saturday morning it was all beat to hell! None of the pipe ends where round so I sent it back. But I can tell you I looked inside the muff and there is absolutely NO packing so it's a chambered muff for sure.
RT
I have had mine on my 6.2 for 5k. It does have a good tone. But there is a drone when in v4. I don't hear it that often but at lower speeds it is noticeable. I let someone else drive it so I could hear how it sounded and I was very happily suprised on the tone and sound level.
cut the resonator and ran a flowmaster super 40, no drone, awesome sound, and cheap.
Did you leave the flapper valve in place or remove it also?
Removed the flapper valve, I could take a picture if you like, even in the wide open position it seemed to me that it would be very restrictive, and I was concerned of it rusting in the locked position which would really restrict flow when wot.
No need for a pic. I am on my third 2014. My last one I installed a 14 inch Magnaflow with turndowns before the rear end. Sounded great in V8, V4 sounded like I was being chased by a Blackhawk chopper. I am thinking about trying just a muffler only swap on this one and leaving the flapper and resonator in place. Yours does sound great tho'
  • 1 month later...
I finally got mine put on and I like the sound, but it's way too quiet for me. A little more db and it would be perfect for me. I'll try to get a video up here this week while I'm on vacation.
That's my thoughts, I'm thinking about taking out the 3rd cat seeing if there will bee any more growl
by removing the 3rd 'cat', will that mess with any warranty besides the exhaust warranty? I've thought about doing the same thing. I don't feel like buying another exhaust but I just want it a little bit louder!
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 580 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
