Mbrp cat back
by removing the 3rd 'cat', will that mess with any warranty besides the exhaust warranty? I've thought about doing the same thing. I don't feel like buying another exhaust but I just want it a little bit louder!
I don't see why it's any worse then putting a cat back on the truck. It's an un monitored cat.
  • Replies 35
That's my thoughts, I'm thinking about taking out the 3rd cat seeing if there will bee any more growl
Removing the 3rd cat does not make it any louder.
RT
  • 9 months later...
reviving an old thread to see if anyone has installed the MBRP single exit catback on their 6.2 since posting on here. Drone and helicopter noise thoughts?
2015 Double cab with a 6.2 and the 3.5" MBRP catback. I don't notice any drone worth mentioning with the exhaust on the highway. There is a bit of the so called "helicopter" noise in V4 but my truck hardly runs in 4 cylinder mode ever so it doesn't really matter to me. Even when it does its pretty mild and the blower fan in the dash overpowers it lol. The only time I really notice it is at slow speeds in town in V4 which I just lock out by leaving the trans in M7. I like it.... and it's my third MBRP catback so I can't really complain.
thank you for the response!
would you say the radio on and or windows open easily overpower the helicopter noise?
how was the install?
Yes and yes for the noise. The install is simple as they come..... it takes more effort to get the stock catback out from under the truck if you don't want to cut it ( which i didn't) than installing the new one. From start to finish of installing the new exhaust once the stock one is off it's maybe 20 minutes with basic hand tools.
