2004 Tahoe Encoder Motor Issue
WMMC
Like a lot of other Chevy 4x4 owners, I receive a message on my dash that reads 'service 4 wheel drive soon'. I know this usually points to a possible encoder motor problem which I really don't want to spend the money on at this time and I have already replaced the 4 wheel drive switch on the dash. My 4 wheel drive engages while driving and at start up with no input from me and at times will not disengage.
I have already removed the fuse labeled '4WD', but this did not stop the 4 wheel drive from engaging on its own.
My question is... Can I simply place the transfer case in neutral and then disconnect the wire harness to the encoder motor assembly to stop the 4 wheel drive from engaging or would this cause other issues?
Well, if you put the T-case in neutral, you won't be going anywhere ...
Neutral on the T-case is used when the vehicle is being towed to avoid driveline issues.
Usually that message is due to a faulty switch .... USUALLY ..... YMMV.
"Well, if you put the T-case in neutral, you won't be going anywhere ..."
You're correct. I incorrectly assumed that the main transmission would still drive the rear wheels because the red neutral light on the 4 wheel drive switch on the dash would sometimes come on while driving. What I did do is make sure the transfer case was in 2-hi and then disconnected the wire harness at the encoder motor. Right now the vehicle is driving properly and no indicator lights are lit on the 4 wheel drive switch. Will this be okay? It will keep it from jumping into 4 wheel drive won't it?
"Usually that message is due to a faulty switch .... USUALLY ..... YMMV."
I have already replaced the switch. In my case it did not solve the issue.
Thanks for your reply to my initial question.
I would get it scanned, you probably have at least 2 codes in the TCCM.
I just spent 2 grand on a vacation and just looking for a way to keep the vehicle from engaging the 4 wheel drive without any input from me.
Thanks for your reply though.
It's fine disconnected , it still needs to be scanned , don't guess as to the problem , you'll be spending money for no reason when you guess and are wrong
Why do people assume it's the encoder every time the message is on ?
Don't you guys know that message means there is a code ?????
"it still needs to be scanned , don't guess as to the problem , you'll be spending money for no reason when you guess and are wrong"
Yes, I realize it needs to be scanned before I spend money on repairs. That's the whole point. I don't want to spend the money right now for scans or repairs.
"Don't you guys know that message means there is a code ?????"
Yes I know.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
