Duplicolor Customwrap Removable coating - anybody used?
Has anybody used the Duplicolor Customwrap removable coating to paint badges, etc?
I saw it on TruckU one weekend but forgot about it until I saw it at Advance. They have a color called Graphite Metallic that is pretty close to Greystone Metallic. I picked up a can and did my bowtie with it. It's pretty close but is a slighly different shade which gives a nice contrast to the rest of the grill. I could probably clear it to make it match a little better.
I'm thinking about doing my badges as well and want to do something different than just black. Has anybody used the duplicolor stuff with good results? I don't want to spray it on the truck and it not peel off as well as plastidip.
Plastidip does have a color called Anthracite but I didn't feel like ordering it yet. Supposedly it's a close match to the greystone as well.
I'll get a picture of it later today in case anybody in interested in seeing the color.
I just ordered some vinyl that isn't quite a match for the wife's tahoe so I'd definitely be interested in how this stuff works.
Edit: they don't have my paint color. :sigh:
That's pretty cool. I've never heard of that stuff. Looks like a pretty close match, and I agree that it would probably be even closer with gloss/clear over the top. I wonder how the back bumper would look???
Not sure. I didn't even think about painting the rear bumper with it.
The only problem with the Duplicolor stuff is that is says to remove or recoat every 6 months for optimum peel. I'm afraid that if I put it on the bumper and clear over it that I won't be able to remove it at a later date.
I might try to find a cheap chrome bumper at the junkyard and test it. I'd rather spend $100 on a junkyard bumper and test it vs ruining the one on my truck.
Yeah that's true. Let me know if you go that route. I'd like to see it. I'm slowly working towards removing all of the chrome from my truck. I only want two colors...gray and black. I've looked into getting the bumper wrapped in vinyl, but that's pretty expensive. I've also thought about just doing it with black plasti dip, until I saw your post. Maybe that Anthracite plasti dip would be close. I really like plasti dip's ability to be peeled off if needed.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
