Found a wonderful design flaw today. Apparently the cup holders in the jump seat fold down console have holes under the rubber insert. Accidentally spilt some coffee where the cup holders are, not thinking it's a big deal because all my previous gm vehicles they were sealed at the bottom. Well they aren't the holes leak through to the back of the console and underneath.
So should the USB and aux ports be ok? Would GM be liable for this?
Ruined a galaxy s5 and an iPhone too, guess no more liquids in the truck.
Yes the new design sucks. It has slits in the bottom of them now. I posted this last year when I got my truck. The cup holder rubber is removable though. I pulled mine out and cut the tabs that hold it down off. Now I can remove and clean it in the sink like the last gen trucks.
Too bad I didn't see it. I attempted to scour the forums before I bought it to be prepared for the little stuff guess I missed that one.
  • 7 years later...
Why would they do that?  Just bought mine yesterday. Driving home from dealership stop at chick fil a.  Must’ve put the straw in the foam cup too hard cause it poked through and a minute later I look down and the cup holders are full of coke.  I stop and start peeling out the rubber liner thinking I’ll dump it all outside on the ground. The level drops.  I get the liner out and it’s got holes!
good thing there’s a hard plastic liner under it holding all the coke. I’ll just scoop out what I can.  Again the level drops.  It also has holes.  Now the Inside of the seat has a medium cup worth of coke soaked into it.  Wtf if the liner can’t be solid why can’t the plastic bowl under it!!     What a stupid stupid stupid design!
does anyone make a liner that’s leak proof?  Any solution to this nightmare. Can I take the back of the seat off only to try and clean it out?  All I can find is having to take the whole front seats out.  What a nightmare I just bought it.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,858 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
