Shift Work???
RyanbabZ71
Any of you guys work shift work?  How do you like it?  Why am I asking?  Well I had a job interview today ( :lol: ) went well.  I just wanted some opinions from you all.  I dont graduate until May so I have still have some time
Ill find out in about 2 wks if i got the job  :thumb:
Are you talking about "swing shifts" or straight 2nd or 3rd turn?
I spent about 12 years working straight 3rd shift.  I actually liked it.  It freed up my daytime hours so if I had an appointment to go to I could do it without taking time off work.  I would sleep 3-4 hours on Friday morning and the get up.  That way I could sleep at night on the weekends.  One big motivator for me was the 10% shift differential, which increased my pay over $2.00/hr (do the math).
I worked 2nd shift for about 6 months and it would be great for a single person, but it didn't work out well for me.
Now that I have alot more vacation and personal time available, Daylight shift is best for me.
I would hate "swing" shifts...  Your schedule would always be screwed up!!!
one wk days, next wk 3-11, next wk midnights
This would be after a 6 month training period (days)
Ahhh rotating shifts .
Nope never done those . but I hear it screws up your internal clock big time .
Got a friend who works at Shields (a local plastic warehouse)
He works one week 6am to 6pm then the next week he works 6pm to 6am . sometimes he doesnt know what day it is  :lol:
Rotating/Swing shifts...  :lol:
If the money is good, then I would give it a try...  You could always quit if you don't like it.
Well at LPD we did rotating shifts from my start time until the last 2 years(this is year 2 of permanents).  We used to rotate monthly backwards.  midnights to afternoons, afternoons to days, days to nights.  Another city here does it every 2 weeks.  I think every week would definitely blow.  It took me around 2 weeks to get the sleep pattern adjusted.  I feel at least in our line of work that you should rotate at least when you're new...and our probationary guys do...to get the exposure to the different work on various shifts.  Afternoons is tough to work.  I'd end up staying up half the night after work as you're wound up, then I'd sleep the morning away and get nothing done.  I've been on permanent days the last 2 and love it.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
