Just picked up my 2015 Sierra 1500 Denali
  • Replies 51
I agree, it's only a crutch lol. I loved the push button start on my old z06.
i do know that if you leave the key in ignition like I do, and lock the truck with the fob..no horn honk reminder.. very odd lol. also if you want to eliminate the dinging while key is in ignition, pull the key out half way and reinsert... no more dinging while door is open and key in ignition...
Great tip! I'm going to try this. It's not quite as convenient as the keyless/push button system where the doors unlock automatically as you grab the door handle, but this sounds like a good happy medium.
I wonder if the 15 Silverado will have the same instrument panel
honestly doubt it. That instrument panel is part of the Denali Package. Even the High Countries do not get it if I am not mistaken.
  • 4 weeks later...
How is the bedliner holding up? Is it something you have to clean often? I am about to get a bedliner and I am tempted to get white but I am still a little hesitant.
Not as well as I had hoped. We've been rough on it, loading in dirt bikes, gear bags, gas cans, loading ramp, etc. The first time I used it, it cleaned up perfectly and looked as good as new. Since then, it's picked up a new mark or two that won't wash off each time. It also doesn't have as much grip as the rubber mats I've had in other trucks. It still looks way better than a bare bed would after all of this loading/unloading of stuff, though.
I definitely like the look of the white liner, a lot in fact. If I were someone who likes to drive a truck but never put anything beyond some groceries in the back, then I think it really adds to the look. It seems like I could spend more time on it, either with some harsher cleaning chemicals and/or elbow grease and possibly restore it to like-new, but since I have a tonneau cover, I just clean it up with car wash soap and a wash brush and run with it. The side walls of the bed still look perfect, but the floor is marking up a bit.
It does look terrific with the bed lights on at night, particularly under the tonneau cover.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
