oem fog lights
Sjjr613
Hey guys just a quick question. I just bought a 2014 sierra sle. It didnt come with fog lights but it has the covers in the bumper for them. My question is, are they pre wired for fog lights both behind the switch in the truck and somewhere near the bumper where they would be installed.
Thank you for any replies
After looking at the GM Accessories available for your truck it appears that they do not have a retrofit kit for the fog lights on the 2014 Sierra 1500.
What I have found with GM is that if there is a way to make a retrofit kit for some option, they will make it. I bought the kit they had for my truck (2010 Sierra 1500) back in 2010, and it came with a new headlight switch, both fog lights, and a wiring harness that connected it all together with ease. The stock wiring harness came wired for fog lights that started at headlight switch, and continued to front fuse panel under the hood. Essentially "roughed in".
I think the 2014 model likely does not follow that design. Is the fog/driving light switch built into the headlight switch in 2014 model? I think you will find retrofitting will not be easy like it used to be. You may want to wait a few more months to see if they will create a retro fit kit.
  • 4 weeks later...
Hello,
New to this web site. However, I have the same problem. 2014 GMC Sierra SLE, V8 4X4 W/O fog lights. It has the fog lamps switch on the dash board lighting control. The bumper has the square plastic inserts for the for lamp bezels. I cannot find any thing on the web to get the lights installed with an OEM look...or anything else for that matter. Any help or ideas would be GREATLY appreciated.
Keep on Truckin
The best (and one of two) I have found is GMPartsDirect.com, item 19170447 Lamp Package for 283.50. Seems to include everything. If anyone gets this Lamp Pkg. please let me know what you think.
That is the kit for the 07-13 GMC Sierra truck. Have you verified the wiring is the same, and headlight switch as well? GM does not show a kit being available for post 2013 model year.
Near as I recall, the foglight assembly just pushes into the opening and uses clips to hold the assembly in place. To work in the 2014 and newer, it would be required to have the same mounting system for the lamps.
  • 1 month later...
