Engine Drain Plug size
I have a 1995 GMC K2500 with the 5.7 engine. Would anyone know what size drain plug the base takes?
I had some work done at the dealer and the mechanic claimed I might need a new base pan because when he changed the oil he couldn't get the drain plug to seal right. He threw away my orignal plug (which I never had any trouble with!!) and put in a new plug. The part number he used is 11562588 which I believe is a 12mm plug, I have read where a 95 takes a 1/2" x 20 and wonder if he used the wrong size plug. If so I hope the threads in the base aren't damaged.
It's not leaking now but don't want to take any chances!! Again I never had any trouble with it and the truck only has 63,000 original miles on it. Any help would be appreciated, I'm wondering if I should go buy a 1/2" plug and change it out if the threads are ok.
Thanks in advance for any replies!
Not sure about the length and thread size, but the 5.7 in my old 98 took a 15mm socket. Drain plugs will get where they don't seal anymore because of the o-ring, but I would have liked to see how it wouldn't seal or at least shown the old one. I'm not sure if you could easily replace the o-ring or not though. I had my 98 for 10 years and did all my own oil changes, never had an issue with the drain plug.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
