295's on Stock 18" Wheels??
Bytor62
I just picked up my 2015 Silverado 2500HD and want to replace the stock tires with Nitto Trail Grapplers, LT295/70R18 mounted on the stock wheels. Has anyone done this yet? Any rubbing issues? I was hoping to just crank up the torsion bars a turn or two, or even get new keys, but want to stay away from a lift.
Thanks!
  • 1 month later...
I would try without cranking the torsion bars. It makes it ride harder.
Assuming you have 265/75/18 The 295 is 1.18 inch wider and .61 taller.
At 65 indicated you will be ding 66.2
The technique I used to figure out what size would fit on my half ton was:
- start the truck and crank the steering wheel to a stop in one direction and loop the seatbelt thru the steering wheel to hold it at the stop while leaving the engine running.
- check the clearances front and back of both tires with a small scale (ruler). The tight areas will be the sway bar and fender liner (front and rear). Taking some pictures will also help for reference later.
- go to the tire manufacturers website and look up the specific tires you have. Write down the dimensions for section and tread width, as well as diameter.
- go to the manufacturers website for the tire of your desire. Look up the specifications and write them down.
- Do the math.. Dont forget that any change in wheel offset or width will affect all of your clearances.
-allow for some clearance. Especially on the things that are not going to give, such as suspension components and frame . The fender liners can move and/or be tied back to give more clearances, Especially the bottom edges. Also, the suspension moves up and down, but the tire does move a slight amount in and out during the travel. Don't be greedy.
- pay attention to where the critical areas are and remember: at the corner of the tire, the tread width and diameter change will both change that corner clearance.
- also figure out how wide you wheels are (or will be) and stick within the tire manufacture's recommendation for wheel width of the particular tire you select.
Have fun. I was able to put 305/60-18 ST Maxx tires on my stock rims of my half-ton without any lift and had no rubbing during driving. Others did have rubbing with similar size tires. But the rubbing was on the fender liners which seem to be floppy and not consistent in shape on the bottom edges.
i run 305/55R20 Nitto Terra Grapplers and have no issues with rubbing. I did also do a 2" front end level.
What type level did u do?
Check this out guys.....http://www.gm-trucks.com/forums/topic/167072-295-70-18-cooper-st-maxx-tires-installed/?do=findComment&comment=1537828
    Brandon 29
    Brandon 29
  • Who's Online   3 Members, 0 Anonymous, 394 Guests (See full list)
