2008 Silvy drivers door inside handle cable
The inside door handle cable broke at the inside handle. Is there an inexpensive way to fix it? The handle is fine. If not is the cable a dealer only item? Thank you guys in advance. MRTJET.
My money says it's the little plastic clips that hold the rod into the latch that broke. Take the door panel off and figure out what broke and start looking for the replacement. If it is the little plastic clips (again, very likely that it is) either buy them at a gm dealer or go pay 2 bucks for some out of a junkyard. Good luck!
Whole door panel is required or you can butcher the door panel all to heck and modge podge something to fix it[/quote you mean to tell me that I have to chop up the door panel to fix the inside door handle cable that is broken? Hmmm. Partsgeeks I just read here has the cable. And I have had the door panel off to see what the problem was. Butcher and Hodge podge to fix this HMMM.]
All I meant was before ya had to buy an entire door panel , or ya can make it work if funds are limited , that's what I meant
