Lower Billet install with Parking Sensors
Kent2500
Instructions for installing the Carriage Works lower billet on a 2015 HD with parking sensors. If you don't have parking sensors, ignore this. If you rather have an official solution from Carriage Works, then wait a bit (I've been emailing them on this issue).
You need a set of bolts (I used stainless steel 1/4" which is a little tight, but works) and bent the provided brackets a little.
The install point is the upper hole behind the parking sensors, see below picture:
If you try to mount the grille at this point this happens (can't get the second screw in).
Not to worry, a little bending to lengthen them out (picture with before and after, note the after is just a little longer, about 1/4"):
Now possible to mount the grill (the cardboard below is to provide a gap):
Now with the cardboard removed...
  • 1 month later...
That looks better! I wondered how long it would be before someone dealt with this issue! Can't believe they (GM) would leave this gapping hole with a cooler right there to get the hell beat out of it!
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 545 Guests (See full list)
