Micro Relay Blown?
dukes
Hello all, I hope I can gain some insight as to how to mix my stupid mistake on my 2014 GMC Sierra SLT. Today I was installing an accessory and (stupid me) shorted out a micro relay on the drivers side fuse panel.
Now as far as I can tell, the only thing that is affected is my back up camera. My screen switches to the reverse screen with the guidance lines but the screen is black. I have looked at the fuses and they all appear to be good still. I am just not sure what to do to remedy this issue.
Thanks.
You need a schematic not the Internet , buy some service information dude, alldata .com
Thanks, for now I have just relocated the camera power source to another relay. This has resolved the issue.
Thanks, for now I have just relocated the camera power source to another relay. The has resolved the issue.
Ya can't do that . It'll become rather warm and maybe melt and stuff like that there
Do it right
Do it right
That is ridiculous. That would never happen. Getting "warm" is not going to melt through shrink wrap.
The back up camera is powered by fuse 31 in the left IP fuse block. But it also powers the transfer case and rear view mirror.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
