Summit White Door Moulding
My door trim is starting to discolor from sun exposure. I noticed this seems to be common in 07-08 models. What have you guys
done to yours besides debadging? Is there a spray paint available?
Thanks in advance!
hit it with rubbing compound, mine were turning black, then I compounded them and they came out good as new.
Thanks elite0259. What kind of compound did you use?
Idk the guys at the shop had some 3m rubbing compound... Now I've got Meguiars Ultra cut and fine polish compounds... either should work really since it's just really bad surface crap... don't forget to wax it after you compound it
