Saddam owns Four Wheeler mag
Black02Silverado
Found this on the web, interesting.
MetroSpy
Makes you wonder if he really does and how much more he owns along with the others living off what we have here. Not to mention if it is even true or not.
Where does it say anything about four wheeler mag? I like Peterson's Four Wheel Driver better anyway...But what can that magazine/company do about it, he owns stock in it and therefore he is a owner, but what could the company do to keep that from happening...I am sorry I just don't understand how the stock market works...
Tom
Sounds iffy to me... as a cynic, I notice how much the site is attacking certain companies, and making it so one click and you cancel your subscription.  That is not a good site
